Self Service Car Wash
Jennysc
- Bike: ER6
Has anyone used a self service car wash on their bike ?
Is it too high pressure or does it work well ?
Thanks, Jenny
Thanks, Jenny
2007 ER6n
2000 GPX250R - RIP 22/04/07
- Blurr
Re: Self Service Car Wash
Never had a drama. Mainly use it at Pi after a CDT run
- young1
- Bike: Ninja 650
Works great i find Jenny..
I use the low pressure soak..give it a couple of minutes & high pressure rinse..chamoi & a wipe down..Just make sure 2 re-lube your chain..soak might strip it a bit.
12 650R Fully Juiced.
- born green
and dont point the jet onto front and rear wheel bearings, they dont like itJennysc wrote:Has anyone used a self service car wash on their bike ?
Thanks, Jenny
96 ZX7R roady
95 tickford XR6,
95 tickford XR6,
- Glen
I think I'd probably avoid it if I could but in the absence of an alternative it's probably OK. As BG said though avoid pointing it anywhere near bearings as you'll just force crap into them.
- Blurr
born green wrote:and dont point the jet onto front and rear wheel bearings, they dont like itJennysc wrote:Has anyone used a self service car wash on their bike ?
Thanks, Jenny
Agreed.
The swing arm linkage is another no go.
Just stand back a bit around those areas
Jennysc
- Bike: ER6
Thanks, I ended up hand washing it in my driveway
2007 ER6n
- photomike666
High pressure is bad for all bearings, and headset bearing are expensive to change. Bucket, sponge and a low pressure rinse are the go.
Wouldn't trust the chemicals they use at car washes, especially the wheel cleaner?
Juggy
I found that my tyres were REALLY slippery when I left. Don't know if it's the wax that you can get out of the hoses but something that I didn't like.
This is my signature and it can say whatever I want.
- KiwiMat
i always wash my bike cold, ive heard some cleaning agents leave spots on engine cases when they dry off a hot engine.
KiwiMat
KiwiMat
ZX12R - 2005
GSXR750 - 2022
FZR250 - 1990
ZXR250A... project
GSXR750 - 2022
FZR250 - 1990
ZXR250A... project
Dafuzz31
I washed it at car wash on weekend and turned out really good......give it a bit of time to cool off before starting (helped on a cold day) then yeah just be careful where and how u spracy.......i did low pres soap......then hi pres soap.....bit of a whipe with sponge ....low pres rinse then dri it off and let the wind take care of the rest....didnt do the wax bit through
- Kermit
What Rob is trying to say about self & non self carwashes.robracer wrote:Wouldn't trust the chemicals they use at car washes, especially the wheel cleaner?
Boat person re-using ragety sponge & chamois after a once 3rd monthly soccermom 4X4 wash vs recycled water with industrial strength detergents & cleaning agents being pressured applied.
- Jonno
- Mobile Chicane
I prefer to wash my bikes in a mankini
My worst fear is the Missus heading in with her BLACK Mitsubishi, hitting the foam button & using the spongy head after some bogan has done the underside of his 4x4 with the same spongy head & dragging debri over the black paintwork..............shudder
then It is my job to fix the swirl marks & scratches
