Air Compressors
- StuMiller
- State: Tasmania
Air Compressors
Any hints, tips and suggestions when looking for an air compressor?
							2007 ZX6 - Road bike
Re: Air Compressors
One with an air hose helps :->
Hth
							Hth
- 6maniac
- Bike: Z750
Re: Air Compressors
Re: Air Compressors
for just normal workshop use - using an air-duster, pumping up tyres & footies   that sort of stuff - just a 2hp unit with about 30l capacity. If you use a lot of air-tools - die-grinders (dremels) etc that suck a lot of air - get a V-twin compressor.
						- KiwiMat
Re: Air Compressors
What Gos said... +1
check out Supercheap Auto for the cheapys
http://www.supercheapauto.com.au/online ... x?id=80101
make sure the hose fittings you get suit the tools your going to use, the cheap compressor and accessory kit i got came with an odd size fittings.
KiwiMat
KiwiMat
ZX12R - 2005
GSXR750 - 2022
FZR250 - 1990
ZXR250A... project
						GSXR750 - 2022
FZR250 - 1990
ZXR250A... project
- StuMiller
- State: Tasmania
Re: Air Compressors
Just curious, I bought one from work that is a V twin, 14cfm compressor. Delivers 240 litres of free air per minute.
I want to be able to run everything from a tyre inflator to a nail gun, duster, wide variety of air tools as well as a plasma cutter.
Came with a water trap for moisture control, snap lock fittings and 20 meters of air hose.
Can't go wrong....
Can't go wrong....
						- Smitty
Re: Air Compressors
I have a Spear and Jackson compressor...bought at Bunnings
single phase 10amp 240v with 40 litre (maybe 50litre?) tank
does everything from rattle gun thru paint gun to nail gun
good bit of kit....
good bit of kit....
				AznCruiser
Re: Air Compressors
I got a supercheap one during one of their sale..............came with a whole bunch of accessories.
Im not a workshop, so a cheaper smaller one is more suitable............so buy an air compressor that suits your needs, dont go overboard buying the most expensive stuff if all youll do it use it to pump tyres (or love wasting good money ).........
).........- Rossi
Re: Air Compressors
Stu,
I know where there's a quite a few cheap air receivers ,
If you're going to be paint spraying or using the rattle gun for any length of time, the bigger tank helps maintain pressure more evenly to the gun
 , If you're going to be paint spraying or using the rattle gun for any length of time, the bigger tank helps maintain pressure more evenly to the gun
						- laidback
Re: Air Compressors
OR if your a lazy ol fart like me and use a rattle gun you def need a decent comp & tank. My 25ltr will only undo 4 wheel nuts on a car before it needs more air...major PIA.Gosling1 wrote:for just normal workshop use - using an air-duster, pumping up tyres & footiesthat sort of stuff - just a 2hp unit with about 30l capacity. If you use a lot of air-tools - die-grinders (dremels) etc that suck a lot of air - get a V-twin compressor.
