He cannot get Pilots as they are in short supply ATM
Views/ comments anyone
I've heard this a couple of times now from different people, although I'm pretty certain it's from the same source. Now while I can't claim to know as much about tyres as my namesake up northscotty37 wrote:Michellin Pilots are made lesser than Bridgies as far as construction of belts...
On the ZZR600 I often got around 14K out of a rear 020.scotty37 wrote:I have just replaced the rear 014 with a 020 which is one sexy looking tyre, slightly harder compound and a far better tread pattern (narrower grooves)and depth, I will wait and see how it fairs for wear and cornering. Hopefully it will be good.
So what's the problem with better grip and quick heat on the road? AFAIK belts aren't a big factor in punctures either, and I certainly haven't heard of any happening...but then as I said I'm no expert.redzedx7r wrote:
I have felt both BT014 and Power side by side and an un-named location (fear of flaming
), the construction of the Power was much softer. This would give the Power better grip and quick heat which would be great for the track. But i also ride on the road and i have heard too many stories about punctures from numerous sources for me to buy Powers.
I think kevlar is a brand name or trade mark. It is also much lighter than steel which is a bonus as it reduces the inertia of the tyre, unsprung weight, etc.Mick C wrote:....and from what references I can find, Aramid fibres are meant to be stronger than steel in tyres...in fact it's a different name for kevlar
