PC V
				Mickwitchy
- State: ACT
PC V
Hi guys,
Prob a stupid question but I have a 2012 zx10. I'm looking to get a PCV. Just wondering: Do I need just a PCV which I think is the fuel module. Do I require the ignition module or do I just need the fuel one. I know there is a secondary fuel module but I doubt I would get that.
Also, I have a stand alone HM quickshifter (for the stock ecu). Will this work with a PCV (even with the ignition module) or would I need a new loom/a whole new quickshifter?
Mick
Mick
- holdontight
Re: PC V
You just want the fuel moduel and its plug and play. Could add a auto tune as well or get it custom mapped. The qickshifter will have nothing to do with the PCV and will not effect it.
							I love my new ZX10. It scares the shit out of me.
				Mickwitchy
- State: ACT
Re: PC V
I assume the fuel only just plugs into the injectors. I would only get a PCV if I got a different map. But, in doing so, would I not need to get different ignition maps (if that's what you call them when it relates to ignition)?
My quickshifter plugs into the coil pack plugs so if I got the ignition module, there would be issues, wouldn't there?
If all I need is fuel module, then it should be ok.
				Mickwitchy
- State: ACT
Re: PC V
Who is serco?
what is an o2 optimiser?
does it matter if I buy from overseas as far as tunes/maps go?
				KEL10R
- Bike: Don't have one
Re: PC V
serco is the sole australian distributer of dynotune power commanders (so they state)
link :
http://www.serco.com.au/kawasaki-2011-p ... ries_id=18
your bike has an oxygen (o2) sensor in the exhaust which the ECU reads to constantly tune the bike (i am not overly mechanically minded but this is how i understand it)
						link :
Re: PC V
It is required for closed loop operation which happens in 4-th - 6th gear 0-7500RPM and 0-20% Thorttle .. your CRUISING range
It will be a battle of ECU vs PCV if you dont do this.
I would stick to Australian supplied for warranty and support reasons Power commander have it plastered all over there web site their store is for US only and if it goes outside your on your own. Unless you can find an amazing deal price wise overseas i would be sticking local.
The OS models don't have a 02 Sensor, so if your buying a link pipe also make sure it has the bung in it for the 02 sensor ... heard of to many people getting caught out with that !
				Mickwitchy
- State: ACT
Re: PC V
Cheers guys, might go local then. Already have a link pipe with o2 bung from danmoto (much cheaper than akra) so that part is sorted.
Thanks for the info
Mick
						Thanks for the info
Mick
- holdontight
Re: PC V
shannony wrote:It is required for closed loop operation which happens in 4-th - 6th gear 0-7500RPM and 0-20% Thorttle .. your CRUISING range
No there saying that there warranty will not be proveided by the local supplier not that they want warrant there product. If you have a problem you will need to have it resolved from you over seas supplier.
I will be going the PCV and Auto tune soon and will be ordering from good old US of A. Why should I pay serco over $200 more for the same products.. I'm all for shoping local but I'm not going to pay almost 50% more to keep the local guy happy.
						Re: PC V
Fair point, i got myn at a pretty good price though i think, $350Aus and on the Powercommander Website they are $379 plus postage ?
I went through a dealer to so hope that gives some ammo if anyone wants a cheap Aussie imnported one, or maybe there are better deals in the US didnt bother look to hard.
- holdontight
Re: PC V
Jonno wrote:So they have got the autotune to work now on the 10R?
Don't know. There advertising it for sale for the gen 4.
I realy want to get the factory computer unlocked but just don't want to kill my warranty just yet. The PCv was/is or will be just a stop gap before I get the computer done. If anything go's wrong I can remove it. I can't remove a unlocked computer.
						- Maccarocks
Re: PC V
Just a quick follow up on what Shannon said about the o2 Optimiser.....
He is correct in that it actually controls the closed loop sector in gears 4 - 6 from zero rpm till 7500.. but this is actually 40% throttle not 20%.. And it does cover the cruise area..  as no matter what gearing you have fitted, you will be in this area in gears 4 - 6 at highway speeds for sure..
It actually richens the mixture up to make the Air/Fuel mixture target a little higher than stock... so it is GOOD for those of you who have removed the cat and have fitted a slip on and / or a higher flow air filter... This info is from lots of emails bouncing back from the 'power commander' tech department..
Macca
    And it does cover the cruise area..  as no matter what gearing you have fitted, you will be in this area in gears 4 - 6 at highway speeds for sure..It actually richens the mixture up to make the Air/Fuel mixture target a little higher than stock... so it is GOOD for those of you who have removed the cat and have fitted a slip on and / or a higher flow air filter... This info is from lots of emails bouncing back from the 'power commander' tech department..
 Macca
Maccarocks
16' - Z1000 (Road)
						16' - Z1000 (Road)
Re: PC V
Cheers Macca, i went through similar e-mail wars  . I'll have to sus out my map the installation for the optimizer states 0-20% and to enter values of 8 in the trim tables
. I'll have to sus out my map the installation for the optimizer states 0-20% and to enter values of 8 in the trim tables  .
I'll sus it out when i get it tuned to see what is happening from 20-40% band
I wish they would get there doco right to !!
Beers Soon !
. I'll sus it out when i get it tuned to see what is happening from 20-40% band
Beers Soon !
