carbon buildup
carbon buildup
Today i pretty much striped the 12 to give it a good clean ,inspection & service .After removing the aibox covers to check  how clean stuff was in there,I opend the throttle and noticed carbon buildup on the back of the valves. The bike is a 2001 model with only 41k . It doesnt smoke and goes like a scalded cat and has no probs with preformance Would the valve  seals need replacing or shimms need doing or maybe something simple any ides.I cant recall seeing this kind of crap on a bike with so few k's.
						Re: carbon buildup
Possible that your running a little tight on the valve clearances. Adjust them and open the slides and give it a hit of Subaru top end cleaner, let it soak for a bit and start her and give it fang around block, she 'll be alright after that.
Re: carbon buildup
unless there is a shitload of carbon build-up - I wouldn't be bothered doing anything. You get some carbon deposits just from normal running, it doesn't mean much at all really. I doubt that cleaning it off the back of the inlet valves is going to make any difference whatsoever to performance ....
