Mounting your own tires
oldman
I'm tired of paying the price of tires from my local dealer so I have decided and purchased my latest rear 190 50 70 Pilot Power II and the tools and am going to mount it myself. I've done this before but it's been a long time ago, any suggestions would be appreciated. They say once you've mounted a tire you'll never go back to women??? I got the tire online for $153.00 including shipping and it's manufactor date is Oct 2012, compared with $265.00 if I buy from the dealer. The dealers tires are usually a couple of years old by comparison. Jim Beam is a given and plenty of lube. I've got two twelve inch spoons and a bead breaker. Any ideas will be appreciated especially the smart ass ones. Cheers!
- Gazza
Re: Mounting your own tires
!!!!!!LUBE!!!!!!!!
Mounting a tyre is pretty much like having sex
the more lube you use the easier it is to get it on
2005 zx10r
Balancing is the easy bit!Smitty wrote:...mounting is easy
the balancing is hard
- tim
Don't ya just spin it on a stick and wherever it stops put the weight at the top? Then repeat until there's no space left for weights on the rim
bonester
Big thing I think is to make sure when mounting and dismounting tyre to ensure bead of tyre is in well in centre of rim. If not it is a shit fight. Heat the tyre in the sun before mounting. The guy who taught me to fit tyres used a big rubber mallet to hit the bead over the rim. That concerns me with the delicacy of the brake discs. I use tyre levers similar sizes to you and use cardboard for rim protection. I do the whole lot with the levers. Bigger levers can chew the aluminium of the rim if you swing on them. Little levers let you know ehen something is wrong- before you do damage. Be careful not to scratch the area where the tyre bead sits coz it may cause a permanent leak. I had a shit fight with a front tyre I fitted second hand to one of my er6s recently- it came off my ZRX originally and I must have stretched the bead slightly in two spots on one side of the bead removing it from zrx. No matter how much air I shot in (tried three compressors) the bastard leaked between the rim and bead and wouldn't pop over. In the end (after 3 hours of swearing and fucking around, I had the idea to use the beadbreaker to install the bead from the inside of the tyre on that side. Job done.
There is a lot of satisfaction to be had in doing this job yourself and if you take your time you know it is done properly. A mate of mine got his first new tyre fitted to his KLR650 here recently by the local dealer- they fitted the tyre BACKWARDS, didn't seat the bead and broke the front speedo drive in the front wheel. Good job wankers.
Yeah I like Kawasakis.
- mfzx6r
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
'01 zx6r
klx300r
- Smitty
- mfzx6r
Smitty wrote:
from the little master himself....
Thankyou
Mario
'01 zx6r
klx300r
'01 zx6r
klx300r
- 6maniac
- Bike: Z750
oldman
Thanks for all the replies. The u-tube video was great. I've done this before but with tube tyres. KY jelly looks like the trick and I have plenty of it. I might try using the leftovers when my wife and I are finished. You know put down a plastic sheet to catch it all. Thanks again, I'll post something when I get it done.
- BrettZZR
- Bike: ZZR1100
- State: Western Australia
Might want to try Y2KY Jelly (Y2K compliant).
It allows you to insert 4 digits where only 2 would go before...
I looked into tire fitting myself - I have not seen mention of rim protectors? Seemed like a good idea.
I also found Dyna Beads. At first I assumed this was rubbish, but the more I looked at it the more sense it made. Anybody tried it?
In the end I found a shop locally that would fit and balance for $25 if I brought in just the wheel and tire. Bargain.
- Jonno
- Mobile Chicane
BrettZZR wrote:Might want to try Y2KY Jelly (Y2K compliant).
yeah go all out and fit moose tubes, no more worries about flat tyres (no it isnt the moose challenge revitalised)
(just kidding)
if i had a 12 inch spoon i would be looking to mount wimmin
s man
you can use a little soapy water for helping to fit & seal the bead. You can also use Armoall. Anything slippry will do the job.
