Fitting PC 3 (Z750)
- 6maniac
- Bike: Z750
Fitting PC 3 (Z750)
Anyone fitted to an '08 Z750 ?
Any hints ?
Any hints ?
Re: Fitting PC 3 (Z750)
Plug it in, zero map.
Take to dyno
Take to dyno
And do the kleen mod while you are at it
- Kermit
Ron's rear back fires alot?Wattie wrote:And do the kleen mod while you are at it
- smithy5
- Bike: Scooter
You will need more than a PC 3 to keep up6maniac wrote:Anyone fitted to an '08 Z750 ?
Any hints ?
Check out cams at least but more likely need a turbo or supercharger.......
- 6maniac
- Bike: Z750
- Kermit
Installation of a PCIII on Z750 looks pretty much plug n play. guide here
Maps here. They are the euro maps, they run similar octane to us as opposed to the sepo's.
- 6maniac
- Bike: Z750
Ta ...Kermit wrote:Installation of a PCIII on Z750 looks pretty much plug n play. guide here
oldman
The Euro ECU has a different part number on the 03-06 Z1000. I don't know if this is true on the 08 Z750 or not. If the ECU is different the Euro maps will not work well. By what I've looked at on this forum the Aussie ECU runs much richer than the one for both the U.S. and Australia. A dealer parts dept. should be able to varify this by part numbers. Cheers.
- tim
I got my PC3 2nd hand out of England for the 6, has been perfect. Installation was pretty easy Ron, plug and play except joining a couple of cables which I soldered.
