Fork seals - weeping
Burky
Post by Burky »
Questions...., after riding yesterday i have noticed that the front left fork is weeping. The Right is not as bad but looks like the both will need to be done.
in the photos you can see the pooling and oil has been blown onto the fairing (not from squirting but from riding).
I was going to drop into the suspension joint this week, so riding on it as is can this cause more damage or should i pull them out now??
Any thoughts?
Did the "Seal Mate" clean but that didn't do anything either.
photo 2.JPG (119.98 KiB) Viewed 3013 times
Re: Fork seals - weeping
If your taking it straight to the shop you shouldn't have a drama as long as the oil isn't leaking enough to get into your brakes or your front tyre. Just be safe
Burky
Post by Burky »
Thanks Blurr, looks like it hasn't hit the brakes or tyre yet thankfully.
bonester
Post by bonester »
What did you say to your seals to upset them? :lol:
Burky
Post by Burky »
The right side is upset, the left blew a seal. i said nothing :shock:
