Road Tyre Pressures.
- Kermit
Gauging what road tyre pressures are people running.
I'm finding that for touring on some of our lovely roads (sarcasm) its a tad to harsh; I'm sacrificing spinal comfort & some grip in the twisties.
Road pressure (cold) according to handbook.
F 36psi (120/70)
R 42psi (180/55)
So what are ya running & what pressures would run on this profile road touring twisties?
I know on the track 30/30 is ideal.
F 36psi (120/70)
R 42psi (180/55)
- fireyrob
Re: Road Tyre Pressures.
I run 36/36 cold on the roady. Different bike I know but it seems to work just fine
Also your on a zx6r what did you expect
- Kermit
Does the Zeddy have the same tyre profile, its also a heavier bike?fireyrob wrote:I run 36/36 cold on the roady. Different bike I know but it seems to work just fine
Its actually a bit softer than the previous model, I should HTFUAlso your on a zx6r what did you expect
- fireyrob
No 190/55 but I ran the same on the 6 when I had the roady.
Yeah 36 in rear is good
- tim
I run 34 34 cold on the weekends on the six - light bike and light jockey
- Chitchats
Im on a Zed and run this, when I check it.
F 36psi (120/70)
R 40psi (190/55)
Heavier bike, heavy rider.
F 36psi (120/70)
R 40psi (190/55)
- Greenblood
On the 7.........
F 34psi
R 38psi
F 34psi
R 38psi
2017 ZX10RR Road
2006 ZX6R Race Bike
1997 ZX7R Pirate MkII
2006 ZX6R Race Bike
- dilligaf
- Bike: Z900
for my triumph, manual says 34 42, I run 34 38.
try 34f/36r cold as a starting point and go from there
it will probably feel a lot better.
- dilligaf
- Bike: Z900
how cold is cold? or should I run lower cold pressures over winter? noticed I lost about 2lbs when the weather turned cold a few weeks back.Gosling1 wrote:try 34f/36r cold as a starting point and go from thereit will probably feel a lot better.
I've topped it up to 34/38 cold and its OK for a while, but its a bit skittish when I get some heat into the tyres. Should I drop to 32/36 or 33/37 or something like that?
36/36 on the Gumby normally but now its colder 34 for both
- ducati_paul
18F 26R ... but then the Enfield may be a little different to your bike
- Nelso
Anywhere from 30-36 front and 34-42 rear depending on the temperature, how much the bike is loaded up, what type of riding and what tyres are fitted.
It's better to understand how pressure effects the tyre performance and get a feel for what the tyres are doing than ask others what they run. Some riders push the front harder than others so they need to run higher pressures so the tyre doesn't deform too much, while the rest need lower pressures to generate enough heat to make the tyre stick. Some tyres flex easier than others, some bikes and riders are heavier than others, some suspension is stiff while other bikes are soft etc, etc. There are too many variables to just ask a general 'what do you run?'. In saying that, I think 36/42 is too hard for a small person on a 600, riding on a public road, in the middle of winter. I'll second Gos and say to try 34/36 as a starting point to see how it feels and increase or decrease the pressure from there.
By the way; what tyres are on the bike and what static and rider sag are you running?
So enough of this talk, when are we going for a ride?
