Water and Fuel, not a good mix
- Burky
Ok so the son washed the bike and did a awesome job, then open the fuel cap only to have water gush in....any ideas?
Will it cause any problems as there wasn't much maybe 100mls max?
I was going to drain the tank (about half full+water) or any other ideas on a fix?
Re: Water and Fuel, not a good mix
Water goes to the bottom I think?
So drain it using the pump, you should get it all out without a drama.
- MAXUMIS
+1 whack some metholated spirits in the tank and ride it until its near empty ..MS dissolves water .Wattie wrote:Water goes to the bottom I think?
life starts at 200 kph!
- Burky
Thanks guy's, i will leave it overnight then drain it.
Just take the fuel line off the bottom of the tank, put a rubber hose on it.
Then turn your key on and it will prime into the rubber hose.
Put it in a bottle and look for the water
100mls ? You sure ? if it was just a bit of backwash from around the cap area, would be lucky to be half that I reckon. Don't bother with draining the tank or any of that palaver - just bung in 1/2 a cup of metho. This will fix the issue no probsBurky wrote:.....Ok so the son washed the bike and did a awesome job, then open the fuel cap only to have water gush in....any ideas?
I was going to drain the tank (about half full+water) or any other ideas on a fix.?........
- Sparks_333
+1 the man is wise..Gosling1 wrote:100mls ? You sure ? if it was just a bit of backwash from around the cap area, would be lucky to be half that I reckon. Don't bother with draining the tank or any of that palaver - just bung in 1/2 a cup of metho. This will fix the issue no probsBurky wrote:.....Ok so the son washed the bike and did a awesome job, then open the fuel cap only to have water gush in....any ideas?
2009 Kawasaki Ninja 650R Green
2010 Kawasaki Ninja 250R Black/Green (Track Bike)
1998 Kawasaki Ninja ZX6R Green - "Fluffy" (Track Bike)
"Never ride faster than your guardian angel can fly."
- tim
pa·lav·er
/pəˈlavər/
Noun
Prolonged and idle discussion.
Verb
Talk unnecessarily at length.
Synonyms
babble - flatte
/pəˈlavər/
Noun
Verb
Synonyms
babble - flatte
- Sparks_333
... Pavlova?
