Starter solenoid??
Felix
State: Overseas
Starter solenoid??
Post by Felix »
Went to take the ER out for a blat today...nothing. Not a sound like it was doing anything. Lights and stuff worked ok. Took battery out, bought a charger, and like I thought, battery was actually pretty good, it only took 30 mins for it to reach fully charged. (By the way basic arlec charger on sale at Supercheap for $15!!)
So I am thinking the starting circuit probably is what is wrong here. Just nothing when I hit the starter, checked fuses under seat and everything is ok. So could this be the starter solenoid? Do I need to take it out and give it a grease or something? This happened last year too, but it seems only to happen in cold weather...which is why I initially thought 'battery'.
- Team Furball -
bonester
Post by bonester »
Had a similar thing happen to my Z440 a couple of weeks ago- went thru everything, including disassembling starter solenoid.....turned out to be dirty battery terminals....duh! :shock:
You in Woomba Woomba ATM? Give you a hand if you are. :)
Felix
State: Overseas
Post by Felix »
Yep, I'm in t'ba...go back to bris tonight, back thurs night (contract finishes then!).
Next Fri -> and on would be ok...but we will have to organise getting the new XJ at some point...
- Team Furball -
bonester
Post by bonester »
Uh huh lemme know if you wanna hand. Got a couple of multimeters. Won't take long. Have you tried push starting? Sure it isn't sidestand switch or clutch switch or something? Tried it in neutral, with stand up???? :)
Felix
State: Overseas
Post by Felix »
Yeah, tried the push start thing...last year that loosened whatever needed loosening, but not this time...can't remember if I had stand up or down, but it would have been up while I was pushing it...
- Team Furball -
a kwaka design fault?? i kno Laines zzr does the same bloody thing..u just hold ur thumb on the starter and eventually she starts to crank....or u switch ignition off & back on a few times until it goes..i think her ignition or her switchblock is farked...
Aussie Ninja
Post by Aussie Ninja »
You haven't left the kill switch off have ya? :P
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
Aussie Ninja wrote:You haven't left the kill switch off have ya? :P
my thought 'zactly
or
its dodgy and is still OFF when you think its ON
Felix
State: Overseas
Post by Felix »
Just for fun I tried kill switch in both positions...but nothing...and I held it down for a bit too. Next weekend I will be able to have a proper look.
- Team Furball -
hit it with a hammer..thats how i fix things when they r too high to kick....
icebreaker
State: Tasmania
Post by icebreaker »
neka79 wrote:hit it with a hammer..thats how i fix things when they r too high to kick....
That's cause your a idiot... And you ride a Honnn.... CiBee Ahhh!
Ducati Monster S2R1000
Felix
State: Overseas
Post by Felix »
Well I read the manual before I went to sleep last night, and apparently they don't have a solenoid, but a large relay. Still it looks like a weekend job...as that is only one of several possiblities.
- Team Furball -
Felix
State: Overseas
Post by Felix »
Well ya wouldn't believe what it was: a bug crawled into the switch block and got squashed over the contact. I have no idea why, but that is actually the first thing I checked. Lucky, eh?
- Team Furball -
bahaha lovely!!!
Felix wrote:Well ya wouldn't believe what it was: a bug crawled into the switch block and got squashed over the contact. I have no idea why, but that is actually the first thing I checked. Lucky, eh?
very insulating.......
