Zx14r steering damper
Does anyone run a steering damper on their zx14r? What sort? How do you find it? And where did you get it?
After reading some forums I am surprised I have not crashed just moving it out of the shed since I don't have one
- Glen
Re: Zx14r steering damper
Probably all bullshit mate. When the Crims were released if you didn't have a steering damper then they apparently just threw themselves into trees on the side of the road. I never needed one other than on the track.
Agree but I am starting to run it down the strip and it does give a little head shake every now and than
Like this......
- ZX14%20Damper.jpg (242.13 KiB) Viewed 8547 times
- zx14%20Damper%20BrockBrock.jpg (29.24 KiB) Viewed 8547 times
Race Hard Or Go Home
Yes like that, waiting to see if there are other option as this is about $800
I did see the muzzy but it like somany others are for the zx14 and I am chasing a zx14r 2012+ , there is a difference but with out setting one hard to tell if they fit our not
- 1400R
- Bike: ZX14R
- State: Western Australia
If your running it down the strip then go for one like brocks kit that allows for a strap setup by giving clearance around the head stock.
You can then return it to stock height easily when you ride home.
You will eventually want to lower it.
If its drag only and will stay at one height then your options are greater.
My plans are to put adjustable rear lowering links and drop the front and rear 1 inch but it will allow me to let me if I go that way
Fitted a GPR V4 today very easy and can still fit straps if needed. Also great service from gpr
