BrettZZR
Posts: 620 Joined: Fri Apr 13, 2012 4:44 pm
Bike: ZZR1100
Post
by BrettZZR » Thu Nov 28, 2013 11:55 pm
Now the second rear tire that has worn so that there are three distinct flat faces:
Now I understand fully why the middle one is there, but why are the side bits flat like that? Why are they not simply rounded similar to when they were new?
Any ideas? (I'll try get a pic)
(-8
bonester
Posts: 2075 Joined: Sun Apr 17, 2005 1:00 pm
Post
by bonester » Fri Nov 29, 2013 12:44 am
Your riding is done at 3 distinct angles only.....
Yeah I like Kawasakis.
Posts: 10041 Joined: Mon Oct 31, 2005 12:23 pm
Post
by Wattie » Fri Nov 29, 2013 5:13 am
What pressure are you running?
smithy5
Posts: 3467 Joined: Wed Oct 15, 2008 11:37 am
Post
by smithy5 » Fri Nov 29, 2013 11:31 am
Probably worn out cause it's tired...........
OR... It's the camber of the Perth roads compared to the US roads..................
It's a
TYRE not a tire
Naked Twin
Posts: 815 Joined: Sat Jan 05, 2008 10:56 am
Post
by Naked Twin » Fri Nov 29, 2013 12:00 pm
As Wattie says what pressures.
Did that to a slick running to higher pressure (followed the instructions of the guy I bought the bike off). Squared it off quite nicely and nearly high sided me off on the final turn at Eastern Creek. Nice lesson to learn
BrettZZR
Bike: ZZR1100
Post
by BrettZZR » Sat Nov 30, 2013 1:14 pm
I never tyre of this banter!
Been running ~36 psi, but I checked it now and its about 32. Is that shape a sign of under inflation?
Given the ZZ11 is no lightweight and there are usually two... ummm.... solid people on it should I be running higher pressures? 40 psi? This tire is on it's way to the bin but I don't want this to happen to the next one too.
What about at the front, what pressure do you suggest there?
Thanks.
(-B'
Posts: 5613 Joined: Thu Dec 30, 2004 4:10 pm
Post
by Jonno » Sat Nov 30, 2013 1:47 pm
What tyre is it? brand, profile/ size etc.
Heavy bikes like my 12R i run 38psi or 40 on long transporting runs. twisty stuff i will drop it a bit depending on the heat/feel/look of the tyre.
Saying that some tyres are constructed differently and behave as such so the pressure is only a starting point.
Post
by Wattie » Sat Nov 30, 2013 2:52 pm
Id be running 42 rear, maybe even a little more
Chitchats
Posts: 506 Joined: Sun Apr 18, 2010 7:17 pm
Post
by Chitchats » Sat Nov 30, 2013 7:40 pm
I run 41 on rear when I check it ! And I'm on a zed.
I agree with wattie probably should be higher to start with.
Maybe change brands? I did on my front due to shit wear patterns.
