Hi,
The other day I was riding through peak hour traffic and the bike shut off on me. I've read up on it and have heard that it is a common problem for the 2005 model. It tends to cut off at 105 degrees and won't turn back on for a about 10 minutes. The revs just drop and then cuts out.
Anyone have suggestions on how to fix it.
ZX6R Shuting off
da_chubsta
- tim
Re: ZX6R Shuting off
Buy a new one, give it to me
One thing discussed on here before is pressure lock in the tank because the gas tank breather pipe is blocked? Not sure how to check if this is the issue? Lift the tank up, pop off the breather pipe and see if it happens again?
When it happens does it start up again?
Could also be a dead battery or bad electrical connection. Any other info?
