Hi guys,
I know the rear footrest design was changed between the D1 and D3 models but does anyone know if the D3 rear footrests fit (or can be made to fit) the D1? The rear pegs are completely missing from the bike.
Also, can the footrest rubbers (front or rear) be bought separately? The parts listing shows only the complete footrest bar with rubber - part numbers 34028-1007/8 - STEP,FOOTREST,FRONT.
Many thanks,
Ian.
Z1R D1/D3 Footrests
Re: Z1R D1/D3 Footrests
G'day Ian,ianp wrote:Hi guys,
Many thanks,
Ian.
Can't help with any info about D1 Vs D3 footrests - but they look pretty similar in the various photos I've seen.
I bought a set of front footrests (bar plus rubbers) from Z1Spares (Oz) for $100-00 - pretty good value and look good too.
You could try (Cycleparts Nation) at this link: http://www.cyclepartsnation.com/oempart ... _cat/parts - I got a RH rear footrest from them - maybe they'll have a LH one too?
Another useful site for Z bits in the USA is Midwest Action Cycles - guess you've tried Z1Parts and Z1Enterprizes already?
Current Project
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
'78 Z1-R
Previous Kwakas
Zephyr 750
H2A x 2
Z1-R x 2
Z900
Z650
H1B
Ok - thanks - will check those sites out.
ian.
ian.
- kawadave
The D1 shares the same frame as the D3.
Therefore rear pegs with fit either.
If you not looking for OEM ...these front pegs are a direct fit for the Z1R......As mentioned above by slimey.
and are a very good replica indeed.
http://www.ebay.com.au/itm/Kawasaki-Z1- ... SwhOxVSF~D
2013 Motogp tipping champ.
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
83 GPZ 750 Turbo
78 Z1R 1000
80 Z1R Mk11
07 ZRX 1200r
83 GSX1000sd Katana
