Hi
What is the set up with valve clearances on '04 z1000 . Shim under bucket or on top . Is there is special tool req"d to remove shims . Job is easy enough on older 70's zeds
Thanks
valve clearances '04 Z1000
Re: valve clearances '04 Z1000
Shim under bucket mate.
Depending on kms, might not even need adjusting.
Pretty easy job.
Pretty easy job.
No special tools rqd
