wheel swaps
- old zx750
- Bike: ZXR750
wheel swaps
i'm wondering if anyone has done wheel swaps ideas to take weight out of my 91-zx750j
i have later model gsxr forks,calipers,shocks ,wheels -lighter weight and fitted to my 88-1100 90-750gsxr's
my 91 is a bit porky compared to my 88-1100- the first time i pushed it around i felt it was light enough to wheelstand
without the engine running ha!
my91 zx750 discs are on min size and i have 01,02 gsxr wheels and discs in good condition and are lighter,
does the 91zx750 really need a 180 rear tyre and heavy wheel? is there a easy wheel swap?
Ken
Ken
zx750j,gsxr1100j,2x 90 gsxr 11/7 builds,gs1100gkd bore to 1200
triumph rigid build, gasser/hot rod build
- old zx750
- Bike: ZXR750
Re: wheel swaps
i got more response on a gsxr site about this question than here, from a guy that was selling his gsxr stuff
because he liked the zxr's better-had done 3 zx9 engine swaps , are the people on here less experement'l
- Nelso
Re: wheel swaps
I don't know much about the J model, but as they say, you can get anything to fit with enough modifications. I have a ZXR750 H1 that I'm prepping to race next year and it only has 20mm axles, so any later model wheel conversion is going to require spacing the wheel bearings down or replacing them. I was looking at E model ZX9, '03 to '06 Z1000 or ZX7R wheels as they have a six inch rear and are still a three spoke design.
I have a feeling that the ZX7R wheels might even bolt up to a J model and you just need to sort the spacers. It's worth checking out anyway.
Re: wheel swaps
I just swapped out the whole rear suspension and wheel setup on my L for a P model 7R rear.
Wider wheel, no torque arm and still factory green!
Nelso; I have a spare ZXR rear wheel if you're after one? Swinger too.
1993 ZXR750 Track Bike
1994 ZXR750 Ongoing project
Re: wheel swaps
the simple answer to that question - is that 99/100 times, the answer is no. Wheel swaps almost always mean some type of custom wheel spacers or change of bearing. But if you have access to a mate with a lathe - wheel swaps can be relatively easy.old zx750 wrote:..... is there a easy wheel swap?......
- Nelso
Re: wheel swaps
I don't know if I can get away with fitting the swinger (it depends how close it looks to a H2 swingarm), but I'm definitely keen for the rear wheel.JimZXR wrote:I just swapped out the whole rear suspension and wheel setup on my L for a P model 7R rear.
- old zx750
- Bike: ZXR750
Re: wheel swaps
thank for the help fellas, i've done 03 arm and wheel into 90 gsxr frame, bearing swaps/spacers for updating wheels
i've got a spare 03 wheel i'll compare weight and look for fit /alignment
- Kwakked Up
Re: wheel swaps
Try this site for plenty of info on different mods for zxr750s
http://homepage.ntlworld.com/webzxr/zxr750r/
06 zx10r - road
99 zx7r - trackie
77 z1000 - project
99 zx7r - trackie
77 z1000 - project
- cowie165
Re: wheel swaps
Oh wow, what a flashback! I remember living on that site when I had my ZXR ten years ago. So much great info.Kwakked Up wrote:Try this site for plenty of info on different mods for zxr750s
And to the OP, dude I have a spare set of ZX9 C rims if you're still looking to try a different set.
- old zx750
- Bike: ZXR750
Re: wheel swaps
thanks,
