Since ive had it, its had this squeal (rubber, im guessing), like the, erm, alternator????? belt is slipping, only at low revs tho, ie. taking off from lights etc etc
dunno if bikes have alternators......my old 250 had this same trouble, but it was the regulator rectifier that had given up the ghost.....
also the battery was bone dry
when the beast stopped, i thought i'd run out of fuel, initially, but a quick check knocked that idea on the head....got my car to the bike( it only ran for 5 k's) threw a set of leads on it, and it fired right up, disconnected the leads, it died within 20 seconds....
to me it seems like its either one, not charging, or two, not holding its charge....
i managed to ride it back the 5 k's home after leaving it hooked up to the car for about 5 minutes, frantically throwing it back together and babying it back to the garage....
if i accelerated more than 1/4 turn, if that, it'd start to die....also rode home with the lights off.....when inside the shed, i turned the lights on, to see what'd happen, and you guessed it, it died straight away....and now wont start again
can anyone give me an idea where to start?.....i still have to get a multimeter, so for now, i cant even check the output of the battery, even should it fire up again......
