Waterpump re-conditioning
B-line
Post by B-line »
Anybody had any luck getting one reconditioned ?, looks like one of the seals has gone in mine, I replaced the O rings but its still leaking, and I really dont feel like forking out $400 for a newie !
Thanks
Bryan
mate...
bike?
model?
year?
sure we can help.... :D
B-line
Soory
Post by B-line »
GPZ900r A1 84 model
Thanks Yoda !
oh..oh
gunna have ta dig into the brain cells for that one
now who had/has a Gpz900..?
tape I think
mate
will investigate and post back
bonester
Post by bonester »
Why not try Independant Motorcycle Werckers in Toowoomba- Warren should have a pump for you- he's pretty reasonable pricing wise too. :)
B-line
waterpump
Post by B-line »
Yeah saw Warren on monday all he has is some 2nd hand ones that he reckons are probably in the same kinda state, he suggested them as a last resort !, and if I cant turn anything up here I might just end up going that way !
Thanks for the reply
Bryan
hmmmm
piccie attached
by the looks, there are 2 seals
- a gasket seal for the front outlet and a rear oring
to seal the back
so
Bryan,
where is it leaking..?
coz there are only 4 possible places...
pinhole in body or cover (alloy has corroded)
out thru the bearing
out thru the oring
out thru the front plate gasket
more info pleeze mate
B-line
waterpump
Post by B-line »
There is a "drainage outlet passage" at the bottom of the pump, and its leaking from there, both the O rings have been replaced so I can only assume it is the bearing seals that are gone, just took it for a quick test and it is not leaking badly but bad enough to worry ! so yeah looks like I need to either get it recond or a new one !
B-line
Bloody thing
Post by B-line »
Now its slowed right up but its now a coolant/oil mix which is a worry, must be seeping thru the bearing, Ok the question still stands does anybody know where I could get it recond ??
Thanks for the help so far guy's !
much appreciated
bryan
Motorbike:TheMostFunYouCanHaveWithYourWillyInYourTrousers
