Help please - Idle adjuster cable.
dh
Post by dh »
Hi all, this is my first time posting in KSRC and this is not how I wanted to introduce myself, but I am kinda in a predicament @ the moment and hopefully someone can help me out.
Long story short, I was playing at the idle adjuster because the idling on my zx7r seems a bit low, I must have opened it too much because the next thing I know, the whole cable came right off. I've took off the tank and airbox to hopefully find where I can re-connect the cable but I can't seem to find it nor does reading the manual helps.
I don't know how often this happens to people, but this is pretty embarrassing as well as depressing watching my bike sitting in the shed because of a stupid error on my part. Anyway, any/all help, advice, condolences :roll:, will be very much appreciated.
Mods: I don't know if this is the appropriate room to post but I assume that posting in general disc. will get the most attention. If this is not the right place, please move my post to the appropriate room.
Thanks.
Damon Z1000
Post by Damon Z1000 »
Welcome to the forum mate, bit unfortunate that, but stick with us and someone will sort you out.
I can't, I'm A '9 rider but there are plenty of 7 riders here.
You may have to wait for them to come home from work though :lol: :lol: :lol:
Team Crash 2010 Ooooops
Welcome, I can't help you either, I gave away carbies last year :lol: . anyway have a looksee here on this members page http://homepage.ntlworld.com/webzxr/zxr750r/index.html
This was posted not that long ago in here and I thought that is was worth bookmarking because you never know, still good for a read anyway while you wait. :wink:
dh
Post by dh »
Cheers guys. I'll check back regularly. Hopefully someone can help me out.
Aussie Ninja
Post by Aussie Ninja »
Got a 6R myself, but quick question. When you say the cable came out does it have the threaded bit on the end or not? If it doesn't have the threaded rod at the cable end you've got problems. I'm assuming of corse that your carbies are similar to a 6R.
6R carbs, idle adjuster on right.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
dh
Post by dh »
Aussie Ninja
Thanks for replying mate. Fortunately, the thread at the end of the cable is still there, the gorilla in me must have been sleeping that day :D .
The picture you posted is very helpful. Couple questions:
1. There seems to be a spring where the cable connect to the carbie, do I need it? because I must have lost it when the cable came out.
2. Can I re-attach the cable to the carbie without taking out the whole carbie assembly? At the moment, the tank and the air filter box are already out.
3. The carbie in the picture, is it no. 2 or 3?
Cheers :lol:
Aussie Ninja
1. Yes. The spring stops the screw from vibrating around and changing the setting.
2. Mabye a little fiddly but I can't see why not.
3. Thats no.1 All the carbies were still together, just hidden by end on pic.
6R idle screw on bike.
1998 ZX6R R.I.P.
2011 ZX10R
mcswaff
Post by mcswaff »
Speaking of the idle adjustment i played with myn probably something i shouldnt have done, well not as much as i did casue now it dont start lol
Ive got a zxr250 yes yes a baby just curious as to how many turns does it roughly adjust out from all the way in to get an average idle any1 know. thanks
Iam What Willis Was Talkin' Bout
Nanna10r
Post by Nanna10r »
Welcome champ. Trial & error it mate, put it out in the sun till lunch time to warm the block then adjust it from fully closed out a coupla turns each time till it starts, half choke blip throttle hard once & dont touch throttle again till it coughs into life, wind it out another coupla turns & repeat till it fires.
Then get it nice & warm & set it too where it sounds right, on a little screamer like the zxr250 I'd suggest about 1300 - 1500rpm when hot, the other thing you can do is adjust your throttle cable near the grip by the tensioner to max 3mm travel at idle. Sorry i cant be more specific. But this should get you there & give you the know how to re do it when necessary.
Cheers Brett
mcswaff
Post by mcswaff »
Pontikat wrote:Welcome champ. Trial & error it mate, put it out in the sun till lunch time to warm the block then adjust it from fully closed out a coupla turns each time till it starts, half choke blip throttle hard once & dont touch throttle again till it coughs into life, wind it out another coupla turns & repeat till it fires.
Cheers Brett
Ok thanks for that ill try it tomorow weather permitting. So 1300 to 1500 ok cool becasue it was idleing when warm below 1000. And that did seem way to low.
dh
Post by dh »
Aussie Ninja
Cheers for that, the throttle cable and I'd suspect the idle adjuster cable connection for my 7r are right in the middle between carbie no. 2 and 3, so a little fiddling around I guess. Anyway, you've been a big help; very much appreciated mate. Now I just have to get my hands on the spring and my bike should be back on the road :lol:.
dh wrote:Aussie Ninja
i got one from a wrecker - they arnt to keen to bust up carbs that can be sold as a unit but if they have some that are cactuc they should take the idle udjuster out and give you the spring and washer.
a new one from kawasaki was over $130 :roll: :shock:
dh
Post by dh »
$130 bucks :shock:, you gotta be kidding! What I planned to do was to find a washer and spring that will fit throught the cable thread and screw it back onto the carbie. It's just a washer and spring right? do we really need to get 'genuine' Kwaka stuff for this, or am I missing something :?
