$10 Carburetor Synchronisation
javaman
Bike: GPz900
Post by javaman »
Some guy had an idea to use pipe and oil to synchronise his twin, so I thought why can't that be used for 4-stroke.
So I bought 4mm hose, garden tap (not needed actually), and a broom handle to make it a bit nice. Put some oil in it.
The theory is for different suction, oil will move -- while when balanced oil will stay put.
So first I balanced carb 1 & 2 (first screw, shown on pic)
Then carb 3 and 4 (3rd screw)
And finally carb 2 & 3 (2nd screw).
And all good and smooth!! Thanks for that I saved $150 bucks (and consequently $200 every 4 months) :D
Don't worry about the bubble in oil. They'll be gone in a week time
Synchronizing carb 1 and 2
-ariel circa 2007
http://GPZninja.blogspot.com/
RG
Post by RG »
More pics pls.
Yankee
Post by Yankee »
4 mill tubing, eh?!
good one!
ty
Bike: Honda
Post by ty »
RG wrote:More pics pls.
yes please - afraid I can't really see what you've done.
Can you show a pic o fthe hoses/broom/oil on their own - and then attached to the bike?
thanking you muchly mr javaman
ty
PS of course you still need a temp fuel source yes?
here is one for $4.
check this out
http://www.airheads.org/content/view/183/78/
Androo
Post by Androo »
I have a set of vacuum guages and feeler guages
if anyone wants some help with their carb sync and valve clearances, I respond
especially well to bribes involving home cooking and/or alcohol :D
(I'm also organising a spanner day in a few weeks from now if anyone is interested)
Androo wrote:I have a set of vacuum guages and feeler guages
do the vacuum guages work well or are the mecury ones better :?:
Androo
Post by Androo »
mrmina wrote:do the vacuum guages work well or are the mecury ones better :?:
well, "vacuum guages" really refers to the general category of devices that
measure vacuum, so mercury falls into that :)
the one I've got is a "carbtune II" and uses light metal rods - its more then
accurate enough to do carb sync :D
(I've also got a free method of doing carb sync .. got within +- 2mgHg using it)
ok.
cos when i was looking around i'd seen actual guages that look like a speedo/tacho. I though thats what u meant.
the carbtune is good. I've investigated it but too pricey.
Androo
Post by Androo »
mrmina wrote:ok.
ahh yes, those things
well you're welcome to use the carbtune if you want (I prefer not to lend tools
out, but I can bring it over for u) :D
goanna_38
Bike: ZZR1100
Post by goanna_38 »
The guage ones are expensive because they have to be calibrated. No point using them if they all read differently to the same amount of vacuum. Friend of mine has a mercury balancer. Instead of using U shaped tubes it pulls mercury from a common tank. Works the same as the guages, you can do all 4 carbs at the same time and you have nothing to calibrate. Saves having to swap hoses like you do with the U shaped glass ones. Don't think you can get them anymore because of the mercury.
If a man says something, and there is no woman there to hear him, is he still wrong?
