Just wondering if anyone else scraps the centre stand on the zzr250 or is it maybe got something to do with my cornering techinque??
Cheers Adz
pretty sure it's the centrestand as it does it on both sides and the new shinny rough polished look sort of makes it easy too spotsmek wrote:you sure it's the centrestand scraping?
my side stand used to scrape before the centrestand, on the lefts.
sorry if this is a stupid response but, i can change the suspension setup on a zzr250mike-s wrote:ive got to ask, hows your suspension setup? too hard, too soft?
I was wondering if it was a bit soft and it was over compressing in the corners a bit.
You don't have terribly much in the way of suspension adjustment on the ZZR-250, but you can adjust the pre-load. I am somewhat heavier than mostAdz wrote:sorry if this is a stupid response but, i can change the suspension setup on a zzr250![]()
