just got a new Micron can for my 9, the so called 'fitting instructions' were crap...a paragraph to tell me whats in the kit, great, like l cant see what l got.
just a quick question, the fitting kit had 1xaluminium spacer and 2x nylon spacers, after some fiddling found that neither of the nylon spacers were required, but since they were supplied should they be fitted???
looked at a mates R6 with a Yoshi and his has no nylon spacers, so l 'm guessing mine is fitted right...rode it nd everything seems right.
any opinions/experiences would be a little reassuring.
Can question..try saying that 10 times...
Simmo_ZX9R
Alcoholic slimfast- not only do you look better, but so do other people
re: Can question..try saying that 10 times...
My slip-on Yoshi on my 6R has no spacers. It fits straight on to the OEM pipe.
I hope this helps.
I hope this helps.
Corbywan
"ZX6R - The laws of physics want their virginity back! "
- mfzx6r
My Art didn't use spaces either.
One thing I did notice was there was a slight exhaust leak so I removed it and run a small bead of muffler puty around the gasket and problem solved
mario
mario
Mario
'01 zx6r
klx300r
Part of the "Fookarwe" tribe
'01 zx6r
klx300r
- Nanna10r
- Team Ninja
Are the washers and spacers meant for the Passenger foot peg mount yes ?. If so my Remus used a washer but a spacer/s would make the can mount sit flatter on the bottom of the footpeg assembly.
Cheers Brett
Cheers Brett
Simmo_ZX9R
Re: re: Can question..try saying that 10 times...
sorry, failed to mention, mine is a bolt on...slip on not a available until 99-00 modelscorbywan wrote:My slip-on Yoshi on my 6R has no spacers. It fits straight on to the OEM pipe.
I hope this helps.
Thanks for the help. l feel better now, so much better now...*singing*
i said it ten time.
so i dont know what ur talking about (or actually didnt bother reading in deatil).
But i can say the topic ten times.
Simmo_ZX9R
hahaha...mrmina wrote:i said it ten time.
but just what is deatil??
its a very bad way of saying detail
