fitted jet kit to 98 zx9r + dyno graph
SocialSecurity
- State: Western Australia
Hi
I had a factory jet kit fitted to my 1998 ZX9R that runs a full akrapovic system, stock air filter, stock everything else...
the mechanic fitted 150 mains on cylinders 1 & 4 and 152 mains on cylinders 2 & 3, and changed over the needles and springs for the ones in the kit
below are links to pics of the dyno print outs (sorry for the quality):
http://www.members.optushome.com.au/nin ... /dyno1.jpg
http://www.members.optushome.com.au/nin ... /dyno2.jpg
the red line being before jet kit, and the blue line being after jet kit. The carbs had factory 142 mains in all 4 cylinders (stock is 155 i think?), but did not appear to have the same needles or springs etc as the jet kit.
this dyno reads a bit lower than most others in the area (for comparisons sake he had a 2000 R1 make 118hp on it) but im not so much concerned about the peak power, but just that its running as good as it should be.
I keep hearing about ZX9R's that want to lift the wheel at 4000rpm in first gear, certainly not something my bike will do in any hurry. Any suggestions on ideal main jet selection, needle height settings, float height etc etc?
Thanks
Thanks
- MadKaw
- Administrator
My 98 zx9 had a factory pro jet kit which also came with 142 mains. Now with stock being 155's you'd think this was a bit lean bit with the other components it worked fine, at first.
My 9 had a full Akro, ignition advancer (4 deg), some head work, intitially the stock filter with the mesh removed then a BMC race filter. It also had straight through air ducts and the exhaust air injection (kleen) system removed so it breathed pretty well... It was running lean so I had it on a dyno to check it out, the clown put a set of stock 155's in it and ran shit.
I then put a set of 158 mains in it and ran like a dream.. last time it was on a Dyno it put out 149.? hp.... on most dyno's it was generally about 143 +....
http://www.factorypro.com/Prod_Pages/prodk67.html
SocialSecurity
just noticed the instructions suggest running 155's on the outside carbs and 158's on the inside carbs if you have a 'competition exhaust system' where it recommends 150's on the outsides and 152's on the inside if you have a stock pipe or slip on, and thats whats in there now ...
think i might try the 155's and 158's along with a +4 degree advancer
might leave the air filter for now, i hear its not a huge advantage any way
but looking at my current A/F ratios, is there anything to gain?
SocialSecurity
- MadKaw
- Administrator
Can't remember the needles but floats were about 13 to 14mm pretty stock I think.
The easiest mod is to take the mesh out of the std filter its worth a couple of HP on its own and doesn't have any ill effects...
SocialSecurity
SocialSecurity
stevew_zzr
I'm no motorbike tuning expert, but i would say that the A/F ratio is probably still a little bit high where you are making peak power. Slightly larger jets may help, but also now that you are running a slightly rich mixutre (looks like about 13.5:1) you really need to advance the timing a fraction to take advantage of the slower flame-front. You'll probably see quite a big gain once you get the timing right (not going to quote numbers).
SocialSecurity
SocialSecurity
ok i fitted 158/160 mains (there were no 155's in my jetkit!), set float height to 16mm (from 13mm), left the needles on the leanest setting, left the pilot screws on 2 turns out... also got rid of the exhaust air injection setup
what can i say... the dunlop D208 on the rear will happily wheelspin in first when cold!
it feels a lot snappier around 5k, the front is pretty light now, i can feel the forks stretching out all the way under WOT
however it still feels a little strangled in the top end
- Aussie Ninja
Nice one. I know it costs money but you need to get her back on a dyno to get it exactly right. Not that I can talk 'cause I haven't, but I'm sticking with the excuse that the nearest one is currently 7 hours away.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
SocialSecurity
SocialSecurity
i was wrong, my filter still has its mesh on itMadKaw wrote:Can't remember the needles but floats were about 13 to 14mm pretty stock I think.
raising the float levels (as in less fuel in the bowls) seemed to help quite a bit, the choke never used to help at all when starting cold, made it worse if anything... now it runs like shit till its warm unless you use the choke
