Engine Oil
- wazza1234
 - Bike: ZZR250
Engine Oil
What oil (brand, types etc) do you guys use on your bikes?  I know what is good in 2 strokes but 4 stroke bikes I  am not exactly cluey on.  Looking at my bike manual (gpx250) it has quite a lot of suitable oils...what to use!!???!!
						- Slow and wobbly
 - Bike: Scooter
				greenmeanie
				SocialSecurity
 - State: Western Australia
i lurrrrve motul 5100, but it is a big exxy...
only reason i occasionally splash out on motul 5100 is that it makes the gear shifts so so sweet cause of the esther additives... and it smells nice
 otherwise motul 3000+ i think it is.... is fine... its a mineral based oil but still has esther in it, and its about 15-20 bucks cheaper than 5100
that said, oils are oils... even safeway oil is good, as its SG rated, and the service manual for my 9R says anything SG rated is fine
well you can use whatever you feel like
Kawasaki spec IIRC SE which is the cheapest out there
BTH which IK and i both know had a jap import GPX with 40K on the clock when he got it , Used the cheap $10 for 4 litres valvoline stuff
changed every 3K and filter every 6K
it got to 130K before it got low on compression after a lot of commuting and a trip around aus
				bonester
Mobil Super XHP car oil in everything (cars included) except ZZR12- use Shell SX4 semi-synth in that. GPX engine is older design- not as oil fussy as later engines....just change regularly with the filter...
							2 X  ZRX1200R 4 X ER6N, GT550, 1988 ZX-10, 4 X GPZ250R, 4 X GPZ900R and GPZ750R
 Yeah I like Kawasakis.
				SocialSecurity
