Dropping a tooth....
- Stereo
Im about to get a new chain and sprockets....
Some people are saying to drop a tooth on the front and add on on the back for better acceleration....
Has anyone done this on a 600?
How much does it affect top speed? (not that it matters all that much)
How much does it affect acceleration?
Does it mean you end up having to change gears a lot more?
- Stereo
I guess it would affect the speedo right?
Someone was telling me that the front sprockets decide the speedo... so if I only add to the rear I will get the same result but it wouldnt affect the speedo....
Does that sound right? You would think they both affect the speedo...
- Smitty
Re: Dropping a tooth....
you can do eitherStereo wrote:Im about to get a new chain and sprockets....
I am a fan of leaving the front sprocket in place and only
playing with the rear sprocket
why??? coz a smaller front sprocket gives the chain a hard time
as it has to go around a smaller diameter...wears the chain and front
sprocket quicker
also
you need to check how the speedo runs..off the front wheel or the
front sprocket
you can calculate the effect if you have a ratio chartHow much does it affect top speed? (not that it matters all that much)
2 extra teeth on the back will drop your top speed 5-8%
and up your revs at 100kmh by roughly the same
maybeHow much does it affect acceleration?
2 extra on the back is good..especially around town
off the line acceleration will beats cages easy
the bike will also wheelie easier..if you wanna do that
some people tend to ride a bike using only a few gears
..they roll on roll off the throttle
others like flinging the lever up and down
really its up to you
hth
I dropped the front by one tooth on the 10 and it was well worth it. It's now the same on the front as the standard for the old 9 was, so I don't think it will have a huge effect on chain life. I put a speedohealer on it as well and calibrated it with a GPS so it's pretty accurate now.
It gets off the line much better than with the standard too-tall gearing, and hasn't caused too many problems with top-speed (other than proving the lie of a fireblade rider's claimed $2.75
) or cruising on the highway.
- Administrator
- State: Tasmania
it's down 1 on the front or up 3 on the back..
Mario and I did it to our 6's at the same time.. I certainly don't regret it
Nikos's is up 3 on the rear.
It is supposed to knock the speed down by about 10% apparently.
Ducati Monster S2R1000
- Aussie Ninja
I went +3 on my '98 6R. Definatley worth it. Just to be nice and legal I fitted a speedo healer at the same time. Feels like an extra 5-10 ponies for the trade off of 500 extra rpm at 60kph and 700 at 100. Top speed is still well above twice the legal limit, so I'm told.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
