Engine Bolts Missing?
James
Post by James »
I took my bike apart this week to give it a thorough check, clean, renew & bonding session. In the picture below, is there supposed to be an engine bolt going through the frame and into the 'collars' on the engine? I looked at the other side and it is the same - no bolt. Its a '89 ZXR750 H1.
check the manual first - it may just be a manufacturing *aid* of some type.......although the engine sure looks like it is supposed to have a 'thru-bolt' of some type ???
be careful, don't just bung in a bolt, that could cause more harm than good......you should check the parts picture as well, it may help identify any missing bits.....
Aussie Ninja
Post by Aussie Ninja »
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
tape
Post by tape »
James my H1 frame has those black plugs inserted on both sides of the frame.
Mick :drinkers:
http://www.insptag.com.au
James
Post by James »
Thanks for the reply's guys. :D I looked in my workshop manual (probably shoulda done that to begin with :? ) and it doesnt mention them as engine bolts in the engine removal section. Perhaps Kawa designed them for a ZX9 conversion! :shock:
I had a thought when I pulled the bike apart. In that pic above, you can see a rusty old nut going into the frame rail which bolts that bracket onto the frame. I reckon if I ditched that bracket (which holds on the fairing inner) that I could use the threaded hole in the frame rail to mount a steering damper! Can anyone see any issues with doing that?
Dj
Post by Dj »
i thought about throwin a set of oggies in there.....mines exactly the same
when you put your fairing back on, notice how they line up with the slots? :wink:
[img=http://img85.imageshack.us/img85/5851/1stdigicampics0189sn.th.jpg]
James
Post by James »
Looking at your pic DJ, I reckon thats a great idea.
tape
Post by tape »
Dj wrote:i thought about throwin a set of oggies in there.....mines exactly the same
I just noted that for the to do list, top idea that. All credit will be given...lol
Mick :drinkers:
