Got the ZX2R on the dyno
Was at a dyno day on saturday with the Oroads group, the little ZX250R pumped out a massive 41.09hp.
I thought that was ok, has a slip on muffler and a air filter.
It beat a cbr250rr and a cbr250r. they got 39hp and 36hp.
So go the kwaka.
AJ
So go the kwaka.
AJ
Well done, not many dyno operators would see a 250 lob in for a test !
also, good to see that Team Green was top of the heap.....
do they make Power Commanders for 250's ?? maybe you could squeeze 45hp out of it...
- mike-s
thats just playing with fire,he's already getting a kickass bit of performance out of it with the current setup.mikk wrote:not bad, not bad. seems nice and healthy.
u could try removing the air box and putting 4 little k&n filters instead. don't forget to rejet it. u should then get a bit more power.
though it might suck when it rains and the filters get soaked?
I've been told by a dyno place, unless you are going to race it and tune it accordingly, DO NOT put pods on, you will loose a vicious quantity of midrange and it will be all go at the top end with not much in the middle. That would make it a much much shittier bike on the road (admittedly it would work fine on the track as your WOT from go to stop).
