I check it basically everyday. But I'm wandering what position should the bike be?
When it's on the side stand my oil level is a little over the lower line on the window. But then when I straighten it up the oil line goes over the top line and virtually fills the whole window.
Now I've heard it should be checked on a rear stand which would mean I have wwaaayyy too much oil.
Basically. Side Stand or Rear Stand to check oil level?
When to check oil.
what he said
I check mine on the center stand, there the back wheel is a little off the ground but my carport slopes up slightly so it compensates. It doesn't have to be that exact anyway just levelish ground, but not on the s-stand that's for sure.
Most bikes should have enough oil in them to reach or cover the top line in the sight glass. In my ZZR the accepted norm is to the very top of the sight glass.
