ZX9R sprockets
SeanZX9R
ZX9R sprockets
Post by SeanZX9R »
Just wanting any feed back on zx9`s setups for sprockets. What brands are better, what size chain etc........
Im thinking of going 14 front 43 back.
Cheers Sean
Re: ZX9R sprockets
SeanZX9R wrote:Im thinking of going 14 front 43 back.
Cheers Sean
:shock: :shock: :shock: considering stock is 16-41 that is a pretty big change. correct me if i'm wrong but that would be equal to putting about 8 :shock: :shock: teeth on the rear.
may also have some issues with a front sprocket that small
SeanZX9R
Post by SeanZX9R »
Thats why im asking for some feed back phil. I was only going to drop the front sprocket by one and not worry bout the rear. But I ve been getting told to get a bigger rear by two or three as well as the front. Ive never done both. Maybe I miss understood and they only meant to change the rear??
Cheers Sean
SeanZX9R wrote:Thats why im asking for some feed back phil. I was only going to drop the front sprocket by one or two and not worry bout the rear. But I ve been getting told to get a bigger rear by two or three as well as the front. Ive never done both.
Cheers Sean
i'd start with 1 down on the front OR 3 up on the back, personally i like it stock....seems to come up ok :wink:
i'm sure damon has the 15 tooth front.
SeanZX9R
Post by SeanZX9R »
Thanks Phil, Think Ill just change the front for now and see how it goes.
Cheers Sean
Rossi
Post by Rossi »
14 tooth front is too tight a radius for the chain and will cause problems with the chain fouling on the guide.
Put a 15 tooth front on and you'll wonder why Kawasaki didn't do it from the start
Rossi wrote:Put a 15 tooth front on and you'll wonder why Kawasaki didn't do it from the start
what sort of revs does that do at 100 & 120 in top ?
Sulli
Post by Sulli »
Gear Ratios - Motorcycle Front/Rear Sprocket Combinations
14 15 16 17 18 19Front
49 3.50 3.27 3.06 2.88 2.72 2.58
48 3.43 3.20 3.00 2.82 2.67 2.53
47 3.36 3.13 2.94 2.76 2.61 2.47
46 3.29 3.07 2.88 2.71 2.56 2.42
45 3.21 3.00 2.81 2.65 2.50 2.37
44 3.14 2.93 2.75 2.59 2.44 2.32
43 3.07 2.87 2.69 2.53 2.39 2.26
42 3.00 2.80 2.63 2.47 2.33 2.21
41 2.93 2.73 2.56 2.41 2.28 2.16
40 2.86 2.67 2.50 2.35 2.22 2.11
sorry the grid doesnt line up but u get the idea 2.56 is standard so to explain 2.56 rotations of the front sprocket =1 rotation of the rear wheel so the higher the ratio the worse the fuel economy the lower the better fuel economy etc etc. To do the job properly you should look at the torque / horse power out puts other wise you will have to change gears like a smoker to keep it in the range also the type of riding you hiway/track commuting do hope this helps
Nanna10r
Post by Nanna10r »
I went 15 - 40 which was down one front & rear.
Makes second a little lower which suits me for the 35k corners.
I believe its the same as going UP 2 on the rear. Put my speedo UP @ 3%.
hth.
cheers Brett
zedx
dropped a tooth
Post by zedx »
I dropped a tooth on the front of my ZX9 . Didn't think it changed much . I raced at Willow Bank and only got a 10.96 with a normal take off i couldn't get a good top speed i think i got up to about 214 k/h but had a good 60 footer .
SocialSecurity
Post by SocialSecurity »
i wouldnt wanna change mine too much, but im keen for slightly shorter gears...
im thinking up two on the rear, maybe down one on the front if its much cheaper
stock mine sits on about 4300rpm at 100kph... would be up around 4500rpm at 100 with two up on the rear or just under 4600 with one down at the front
diesel
Team Piss Head
Team Piss Head
Post by diesel »
i went one down on the front and i really have to wonder why it wasn't built like that.
i got more punch and more top speed cos it had more balls to get up there.
greeny
Post by greeny »
1 down on the front and whack a 55 on the rear.
Turn that bike into a fun machine :D :D :D
2007 Husqvarna SMR450
SocialSecurity
whats the chance of being able to fit a +2 rear sprocket under my existing chain? its stretched a little, but is +2 gonna be too big? :P
greeny
Post by greeny »
Only way will be fit it and see.
You can always add a link or two.
