Anti-freeze?
- Aussie Ninja
Anti-freeze?
Just wondering what sort of anti-freeze to use? Seeing as my scoot last had its coolant changed when it was shimmed in Rocky I'm pretty sure the anti-freeze properties of whatever they used wasn't of major concern. So in anticipation of winter I thought I'd refill the system with something with good anti-freeze properties. Just don't know whats best to use?
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
mate, your standard kawasaki coolant will be fine - most if not all coolants have anti-freeze / anti-boil properties anyway.......and if you garage your bike o/night here, you won't have any problems with coolant freezing anyway......
mind you, those -10deg mornings can still test things out
- Strika
I have never heard of using shit coolant Gos. But I have seen someone use piss coolant in a pinch. The key is not to let it overflow when Hot. peeeewwwwwGosling1 wrote:chameleon wrote:Bloody hell Goz! Do I have to buy special BIKE coolent as well as special BIKE oil'ken oath mate, your bike will seize if you use just any old shit coolant !!
- photomike666
Damn, I thought they were aircooled with a dry sump? So I oil my chain with lube, will this lube my gearbox like sump oil? and this anti-freeze - does it work on my brain when I eat ice cream?
Seriously, a good anti freeze will enhance the cooling ability of your coolant and is worth its weight for the hot climate. Most are now, but check the one you get is suitable for aluminum blocks.
