tyre pressure for the track?
- MrStompy
hello
just a quick question about correct tyre pressure to use when riding on the track
I got a pirreli diablo 180/55/17 on the rear and battlax bt019 120/70/17 on the front
reccomended pressures are 42 rear and 36 front
what should i run them at on the track?
last time i just dropped them about 2 psi each and it seemed ok but i have no clue so i thought i should ask so i can get the most out of it
thanks
thanks
- Strika
Do be careful with mixing those front and rear tyres dude, some people in here take a dim view of it
I have no direct experience with the tyres you are talking about. Some tyres require lower pressure than others to get them to work.
A certain race tyre I run has to be run as low as 26psi to get it to work, where others must have as much as 32 in them.
If a 2psi drop worked for you last time, then I would stick with that. The lower you run them, the quicker they will come in. But also the faster they will drop off in performance on the other side.
As a guide a 5-7 psi increase from cold to hot pressure is about ideal.
- MrStompy
Yeah i wouldnt normally mix them but i split the rear in the nasho and had to take it to the nearest store to get it fixed/replaced.Do be careful with mixing those front and rear tyres dude, some people in here take a dim view of it
I was limited with choices so i paid out my ass for the pirrelli cause he said it was the best he had.
i will probably replace the front soon with a matching pirelli cause i like the rear so far.
- Nanna10r
- Team Ninja
There're not Mixed .... they both are 17's
. You'll be right champ I run a couple pound less front n rear at the track to 30F 32R but my tyres are mixed having an 18' rear.
Cheers Brett
Cheers Brett
If you are only going to do short legs of say 5-6 laps, you want them set pretty *soft* if you are going to build up heat quickly (got any tyre warmers ?) - I *think* you need to drop a bit more than 2psi, but these things are always determined by *what suits you best*.
Recommended pressures ? start with 32 fr, and 36 rr, and take it from there........if you are doing longer legs of say 12-15 laps, then a bit more pressure at the start would be a good idea......
Good luck with the racing dude........
i will go with 33/30 but it depends on the tyre and the rider you just have to try it out and see what works for you.
Could save a lot of time and go a whole lot faster and go and get a set of secondhand slicks from somewhere for 100 bucks and get them fitted at the track, I used road tyres for the track for a long time but once you get the slicks on the whole thing picks up 150%.
Slicks where designed for racing and road tyres are designed for the road.
ohh i put 29/27 cold into a dunlop slick and dont use warmers cause i live in Qld.
- HemiDuty
- Bike: Don't have one
I used to run between 28-32 in the rear Diablo that came with the old 7 when I bought it. Same in the front. I would go 32 at first, it will feel different. But high 30s and above sure sounds like too much pressure to me. I have run slicks as low as 26 and know people who have gone lower, but now I just go with around 30 and look more to the hot pressure to tell me what is going on. Not that I ever know what is going on.
Drmsby Middleton
DC Racing
Extreme Motorsports
M2R
Castrol
ColourSmart Chroming
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
DC Racing
Extreme Motorsports
M2R
Castrol
Hi Side Leathers
Teknic
Sidi
DID Racing Chain
Goodridge
- Glen
I used to run 30/30 at EC on the ZX9 with Metzeler Rennsports. Used to work well. I got the concept from Pat Galvin (Metzeler Distributor) who knew shitloads more about tyres then me.
I should add I'm by no means the fastest bloke out there but would usually wobble around in the front half of the medium groups.
- Nanna10r
- Team Ninja
Good Advice "Narfie" Keep it up champ.Neka79 wrote: i have run 28m with my knees together to the porta potty. but that took all my power not too dump on the track ...... toilet seat grips ok .... but by the second session "i have to go GI Joe cause me undies are full"
I use to run from the rear like a "busted Mains pipe", sh$t would run out of me leather pants & once made me rear wheel spin, so i had to drop me undies a tad more, found i loved it, So took all me kit off and became more confident about hanging on with me bum cheeks..... still aint got a knee down but i did manage to drag me left cod at Mallala ...... getting the Gayblade off the trailor.
2000 cbr929rr "Gayblade"
1988 kdx200-now sold... "swapped for a pack or Winnie Reds"
198? cb150 bucket-any one wanna buy it? "Half full of Vomit but not full ..yet"
1996 VS series 2 S pak Ute "10 years old & so is the Mattress under the taunea"
Cheers Brett
- Strika
Pontikat wrote:Good Advice "Narfie" Keep it up champ.Neka79 wrote: i have run 28m with my knees together to the porta potty. but that took all my power not too dump on the track ...... toilet seat grips ok .... but by the second session "i have to go GI Joe cause me undies are full"
1996 VS series 2 S pak Ute "10 years old & so is the Mattress under the taunea"![]()
Cheers Brett
