Master cylinder bleeding
- Aussie Ninja
I've been having dramas getting all of the air out of my master cylinder since fitting braided lines. Today I took a novel approach to the problem. Air bubbles always end up in the highest place, so I simply made the callipers higher than the master cylinder by unbolting it from the bars and threading it down through the front fairing to below the callipers. I then proceeded to bleed the brakes and what do you know, out comes a decen't chunk of air. Overall it was a bit fiddly but the result was worth it.
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
- Aussie Ninja
