brakes squealing
smek
brakes squealing
Post by smek »
just noticed today that my front brake is squealing a bit .. ya know that classic brake squealing sound.
i put new pads on maybe 500k's ago.
any advice on what's likely to cause it and what i should check ?
Flakey
re: brakes squealing
Post by Flakey »
Put some oil on em, that'll quiet them down... Acutally don't... :D
May find the pads might be glazed (depends on how you use them) and need roughing up.
If you don't heat them up enough when riding, then the pads go 'shiney' and make wikud noises... Still work ok tho. 8)
That's my 2c anyway.
smek
Re: re: brakes squealing
Post by smek »
Flakey wrote:Put some oil on em, that'll quiet them down... Acutally don't... :D
lol
Flakey wrote: If you don't heat them up enough when riding, then the pads go 'shiney' and make wikud noises... Still work ok tho. 8)
could be a possibility .. did a couple of reefton runs after putting them on but lately its only been commuting.
Re: brakes squealing
smek wrote:just noticed today that my front brake is squealing a bit .. ya know that classic brake squealing sound. i put new pads on maybe 500k's ago. any advice on what's likely to cause it and what i should check ?
nikos...
glazed pads would be my diagnosis
'glazed'? as in the pad surface gets shiny coz the pads have not been bedded in
fix?
take pads out....find nearest concrete footpath or driveway
rub friction side of pad on concrete to roughen 'em up
(watch knuckles or fingers don't get the same treatment :lol: )
and DON"T breathe in pad dust!
then
get emery paper and rub disk rotor across the disk, NOT round and round...
(and do both sides) where the pads rub
then put pads back in
find quiet street or carpark
go thru 8-10 hard stops (don't lock front brake) from 50kmh down to
10kmh (beds in brake pads)
then go for a ride and use front brake normally
come home and let cool down
problem should be gone
Felix
State: Overseas
Post by Felix »
If they are glazed, I am pretty sure there is a paste you can get that you apply to the pads, then just go for a spin. :?: :?: :?:
- Team Furball -
Felix wrote:If they are glazed, I am pretty sure there is a paste you can get that you apply to the pads, then just go for a spin. :?: :?: :?:
ummm...
toothpaste?? valve paste??? BonAmi??
been doing brakes for 30 years and thats a new one on me.
any more info??? please
smek
Post by smek »
Thanks everyone. you rock :rock:
Rossi
Post by Rossi »
are you sure that you're not talking about copper paste which goes on the rear of the pad ??
Felix
State: Overseas
Post by Felix »
NFI.
My mech used to have some stuff that he put on the disks/pads of my car...actually two mech's did...buggered if I know what it was...
'member, me'em just bush'canic cuz!!
Flat tyre = kanga-grass in tube...
...and so forth...
- Team Furball -
My brakes are opposite of that. When I pull them on they feel like they are loose and jumping around all over the place. They also make a grinding noise when I use them.
I have checked calipers etc and everything seems to be ok. I guess that's just the way they are.
Nanna10r
Post by Nanna10r »
Hey u farllas doen go Fukin wi' Felizx, he alrigh aye, Him top farlla bush canic roun ere, so git th fuk outta th way an gib the man soem rooom. Lionel where u put th plagoon ?.
Cheers Felix' Pruductions
c/o That motr aint fuked till we get nother Karton . 2004.
Wannabe
Post by Wannabe »
aardvark wrote:My brakes are opposite of that. When I pull them on they feel like they are loose and jumping around all over the place. They also make a grinding noise when I use them.
Sounds to me like your pads might be cooked. You should try deglazing & bedding in the pads (as per Yodas previous post) and if that doesn't fix it, may be time to replace them. I used to have the same problem on my ZZR & 95 ZX6, particularly with some of the SBS pads I'd used. I now use only OEM pads or EBC-HH and I couldn't be happier.
Pontikat wrote:Hey u farllas doen go Fukin wi' Felizx, he alrigh aye, Him top farlla bush canic roun ere, so git th fuk outta th way an gib the man soem rooom. Lionel where u put th plagoon ?.
BWWAAAAHHAHAHAHA :lol: ROFLMAO
Ride Naked!!!
icebreaker
State: Tasmania
Post by icebreaker »
I want what Brett's smoking...
Ducati Monster S2R1000
Wannabe
Post by Wannabe »
Well whatever he's on, I doubt it's legal.
Ride Naked!!!
Nanna10r
Post by Nanna10r »
icebreaker wrote:I want what Brett's smoking...
What ... Holiday Kings 2mg .... in the Economy Palette ?.
Filthy Habbit !. If it didn't keep my hands out of my Pants at dinner parties I would of given up Years ago.
Cheers Brett
