Will a 98 ZX6R upper fairing stay fit a 95 ZX6R ?
swabio-ACT
Post by swabio-ACT »
Righto ppl,
I am after a fairing stay to be used with my race glass..... the only problem is.... that there is a lack of 95 ZX6R fairing stays around.... however there is an abundance of 98ZX6R ones....... will it fit? How different are the upper fairings ?
Cheers :)
EDIT: this is the kind of thing i am after..... http://www.gravesport.com/cgi-bin/shopp ... ey=FB__021" target="_blank
Link fixed...
Re: Will a 98 ZX6R upper fairing stay fit a 95 ZX6R ?
they are a little different Rich! But if you use a Suzuki special tool (A Hammer) it could be made to work.
swabio-ACT
hmmm how much different are we talking? Do you think it will be just a matter of a slight bending process? Are the lengths about the same?
swabio-ACT wrote:hmmm how much different are we talking? Do you think it will be just a matter of a slight bending process? Are the lengths about the same?
Ugly different mate! Get some small dia alloy tubing and mock it up yourself with a pipe bender, then get it welded. I have a non farked one here which you can borrow for a template if neccesarry. Not like you havn't got the time! ;)
swabio-ACT
hmmm cheers mate, I might take you up on that offer..... btw are the points which mount it to the actual frame the same......I have had another idea.....
I could get this....
and then just get a couple of ears made to make them finish in the same location as your stay....
