losing power at 6000rpm
fallen_punk
hey all i gots a 96 zzr 250cc and im losing power at 6000rpm under load any thought or help would be great i have checked plugs,leads,and air filter not sure wat else to do.... thanx chris
- Aussie Ninja
re: losing power at 6000rpm
Your exhaust doesn't sound different does it? If the muffler has collapsed it could block airflow and choke up the engine. Does your bike have an electric fuel pump? If its nearly stuffed it might be able to keep up with the engine down low but the carby bowls empty out when you get up the bike a bit. Is your fuel filter partially blocked?
Help me out here guys. If one carbie has a big problem in the main circuit can it cause this?
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
1998 ZX6R R.I.P.
2011 ZX10R
- Quarkz
I thought the Zed 250's lost power through the whole range
Mine sure feels like it does. Im guessing it's a carby problem. Welcome to the forum by the way!
Kylie
2013 Kawasaki ZX636 / 2004 Kawasaki ZX636 / 1999 Aprilia RS250
- Nanna10r
- Team Ninja
Welcome to ksrc Chris. Sounds like fuel dramas to me. Theres lots of clever Blokes from Down south that would have more idea the i though. Hope you get it sorted an we see you out on the black stuff soon.
Cheers Brett
Cheers Brett
i had that on my gpx 250. when it revs to 9000, it loses power and fires up again when it reaches 2000.
it also back fired once or twice. got the carbies balanced and it never did it again. Til this day i have my doubts thats what it was, but hey it worked.
there is a very cheap way to balance the carbies, but it works well.
Felix
- State: Overseas
If it was an older car I'd say check the vacuum advance vacuum hoses etc...but I am not sure what they stick in those things...crap spark, crap timing, blocked fuel filter, crapped up carb could all possibly be the problem. Maybe.
Fuel filter cheapest and easiest next best move I reckon.
- Team Furball -
- aardvark
You sure it's losing power and not the clutch slipping?
fallen_punk
thanx to all who helped out it was the carb!! and the air filter was shaged thanx guys for ur help.
