Also didn't think it would be difficult to replace but here's the procedure:
Remove the bolt in the end of the handlebar that retains it. Remove the bolt that goes vertically into the bottom of the tripple clamp from the clipon clamp. Remove the steering head nut. Release the fork tube clamp bolts in the upper tripple clamp. Pull the upper tripple clamp off. Now release the clip on clamp on the side in question and slide it off the fork tube. The clip on has to be off the fork tube to remove the handlebar tube.
My rant for today.
