'98 zx6r rotors
idh959
'98 zx6r rotors
Post by idh959 »
Guys,
It'll soon be time to change to front brake rotors on my zx6r. Theyve got more grooves than an old LP. Do you have any suggestions what to go for, where and how much?
Cheers.
Aussie Ninja
re: '98 zx6r rotors
Post by Aussie Ninja »
If moneys no object go for galfer wave rotors. They are supposed to be a kilo lighter than stock for the front pair. I'd order from the states. Expect to pay $500 US for a front pair. I like supporting the local guys but when you can save $100 or more on stuff.....
1998 ZX6R R.I.P.
2004 ZX10R killed by Roo.
2011 ZX10R
idh959
re: '98 zx6r rotors
Post by idh959 »
Thanks for the tip however, money is an object. Also what are the differences in materials. Correct me if I'm wrong, but I think I saw somewhere you can get stainless steel discs or cast iron discs.
Aussie Ninja
re: '98 zx6r rotors
Going from memory here but stainless rotors are of corse harder and are designed to be used with metal pads and work better than iron ones that are softer and use organic pads. If money is an object go with EBC pro-lite oem replacement rotors.
1998 ZX6R R.I.P.
2011 ZX10R
Barrabob
re: '98 zx6r rotors
Post by Barrabob »
Or try http://www.chaingang.com.au they do aftermarket and the price is suposed to be quite reasonable.
Damon Z1000
re: '98 zx6r rotors
Post by Damon Z1000 »
Chain Gangs the one bud, I had a hell of a game trying to source a decent pair for my 9 and had to go for new in the end.......
Ring em tell em your gonna send em for new rotors and they should turn em round in about 3 days........decent wavy rotors $480 pair built onto your carriers and they do a nice job.
Mine are spot on 1500k's and bedded in nice.
Discs with 150 k's still got machining scoring, that wears smooth with time.
After Rebuild Small Size 011.jpg (189.21 KiB) Viewed 3637 times
Nanna10r
re: '98 zx6r rotors
Post by Nanna10r »
Another option in Graham up here in Brisie both Dan & i got him to do ours no complaints from me. Check out the link for the discussion.
http://www.ksrc-au.com/phpBB2/viewtopic ... ght=graham
cheers Brett
Yankee
re: '98 zx6r rotors
Post by Yankee »
and what is better......
drilled discs (as in "holes")
OR
Slotted discs???
Nanna10r
re: '98 zx6r rotors
Post by Nanna10r »
Most of the (non genuine) replacement discs I've seen are slotted Marty. I thinks its less time consuming to make slots. It shouldnt make much difference unless you let some duckhead like the mecnaics at Yamaha West put the buggers on backwards .............. Idjits :roll:
Cheers Brett
