ZX7R Forks
ZX7R Forks
Cos i bought my bike second hand and i think the Kawasaki manual could be wrong.
Can some one please tell me the distance C (in the pic). I need to know the standard setting, so can someone shed any light who has not changed their fork settings since new/factory.
A is the top of the fork not including the cap
B is the top of the triple clamp
C is required
Its a 1997 ZX7R-P2
PLEASE :!:
re: ZX7R Forks
ok.... no answer.
Can someone tell what there's is set to.
Re: re: ZX7R Forks
mrmina wrote:ok.... no answer.
I believe it is only about 2 or 3mm stock so make it about 5mm..
Re: re: ZX7R Forks
I agree with Dave
a lot of the bigger bikes (the 7r my Gpx and 6s I think ) have that distance set at 3mm....
I set mine at 5mm
I will check the ZX7r and ZXR750 manuals when i get home tonite
Re: re: ZX7R Forks
I agree with Dave
I set mine at 5mm
To double check I found a zx7r brochure that has a good pic of the forks tops and the dims I gave look about right.. You can see about 3mm of gold fork tube above the triple clamp..
re: ZX7R Forks
mina
had a look in the books tonite
ZX750 J and K models is...11mm
ZX750 L is 5mm
ZX750 M and P is 10mm
hth
re: ZX7R Forks
cheers.
i was just think of experimenting 5mm at a time with the front and maybe play with the back.
