oil level window replaceable?
smek
Post by smek »
while my bike was sliding down the road, the rear brake lever has been pushed into the oil level window and cracked it, it seems pretty flimsy. I can't see it lasting without being replaced.
Is this a replaceable item or what ?
re: oil level window replaceable?
nikos
what year/model is the zzr?
need to know
the GPx2fiddy one is replacable
and I assume the ZZR one is too.. but to be certain..model/year pls
smek
Post by smek »
Thanks ian, it's a 2001 or 2002
Looks like to change it you have to take the cover off the sump (or whatever it's covering).
Felix
State: Overseas
Post by Felix »
It probably would be, maybe with the use of some oil/fuel resistant epoxy...
- Team Furball -
Re: re: oil level window replaceable?
smek wrote:Thanks ian, it's a 2001 or 2002
yeah Nikos
the clutch cover has to come off to the replace (the GPx) one
so i guess the zzr is the same
Duane
Post by Duane »
Looking at jess's u would have to take the cover off...
Then again its a 250, most people dont even put oil in them, except the used stuff out of the car :)
Good to see you're back on your feet already thinking about fixing the fker
Need any help let me know, ill try and get my hands on this manual next week and scan it up
www.bromancer.com.au
smek
Post by smek »
Duane wrote:Looking at jess's u would have to take the cover off...
Is there much behind the clutch cover? other than oil ... ie is it a pain in the arse take off? or just a case of draining the oil and taking it off...
Just asking cos i dont have the manual yet and all i can think about is fixing me bike :)
Duane ... you da man, if you can't be fucked scanning it, I'm happy to pick it up and do the scanning then i'll return it in similar condition ;)
dave#3
Post by dave#3 »
smek wrote:Is there much behind the clutch cover? other than oil ... ie is it a pain in the arse take off? or just a case of draining the oil and taking it off...
Nikos, I replaced the oil window on Cath's old ZZR after a minor driveway incident. From memory I dropped the oil, unhooked the clutch cable and removed about 6 bolts. The whole operation took about 20 mins and I didn't need to replace the clutch-cover gasket (I think I still have one in the shed actually)
http://www.oz4x4.net/gallery2
