oils aint oils
blackninja
oils aint oils
Post by blackninja »
ive been reading the viscosity ratings on oil containers and theres not much difference between high performance car engine oils and motorcycle engine oil and am now wondering whats the difference between the two?
03 zx6r blackninja
回転日本語私は実際にそう考える
Barrabob
Post by Barrabob »
About 80 bucks a bottle. :P
Bike oils dont use friction modifiers which make the clutch slip there are some caroils which will do the job but for what its worth i stick to the bike specific stuff.
a google search on the subject would be imformative and i know most of the lists on the good cheap stuff are made in the usa so we dont have the product local.
blackninja
oils aint oils
yeah okay so the car oil is actually sliperyer because of the friction modifiers would that make it better for the engine and gearbox allthough no good for the clutch?
some of the car oils a pretty pricee too
03 zx6r blackninja
回転日本語私は実際にそう考える
javaman
Bike: GPz900
Post by javaman »
Well after some soul-searching I put Valvoline Premium XLD at $17 (5lt) as opposed to Motul 5100 at $50 (4lt).
Here is the specs: Motul is API grade SG, Valvoline is SJ so a no-brainer there. Manual says to use at least SG grade. SJ stuff ... good :D
Yes my only worry was clutch-slipping, but that proved to be of no-concern. Wheelie ... no problems :lol:
Gear changes, could not feel any difference.
Of course the only advantage is Motul being synthetic, but then why graded at SG?
-ariel circa 2007
http://GPZninja.blogspot.com/
Poyda
Post by Poyda »
Viscocity is also an issue to keep on mind, if the oil is too thin, especially when hot, it just won't do the job properly.
I'd rather spend $50 on a product designed for bikes, Valvoline make them too, rather than something that has ingredients that probably arent doing you any favours.
Just my 2cents
Pete
The (no longer) ugly 96 ZX6R
SocialSecurity
Post by SocialSecurity »
ive been using $12.99 valvoline SG oil .... but only because safeway had none of their $10.99 safeway brand SG oil :cry:
kawasaki recommend any SE, SF or SG class oil, in a wide variety of grades. im using 20w-50 i think, and it was on the ok list... tho i would prefer 15w-50, or maybe 10w-40
motul 5100 is great stuff, but way too expencive.
krusty
Post by krusty »
javaman wrote:Of course the only advantage is Motul being synthetic, but then why graded at SG?
I think they stick to SG because the newer ratings may call for lower amounts of zinc or phosphorus, which are clutch safe anti wear additives. If you want an oil with lots of zinc look into some of the diesel oils.
I've tried Mobil S 15W-50 semi-synthetic and Caltex Havoline semi-syn 10W-40 (even mentioned it can be used in bikes on the label) in my 250's without problem.
Re: oils aint oils
blackninja wrote:ive been reading the viscosity ratings on oil containers and theres not much difference between high performance car engine oils and motorcycle engine oil and am now wondering whats the difference between the two?
..pardon?????
the difference between say Penrite SIN or Castrol EDGE 0-40w or Mobil1 and a top grade bike oil is huge
firstly a fully syn oil is never recommended on a bike
until its fully run-in (2000k+)
then
most car oils have friction modifiers in them
...use it in a bike and goodbye clutch
and finally
If you luv ya bike gearbox..don't use a car engine oil
the car oil is missing the bits that protect gearbox bearings
the oil gradings may be the same..SE SF SG or 10w-40
but
in short..use a bike oil!
my 2c
SocialSecurity
the SG oil i bought (havoline sorry not valvoline) says its suitable for motorcycles and cars
...and so do kawasaki :P
javaman
Bike: GPz900
Post by javaman »
The valvoline actually is used for car gearbox as well :D so there you go, one type of oil for my civic (engine and gearbox) and zx6r :D
All as recommended by the manufacturers...
SJ is better grade sure, and longer engine life, but yeah there is a big mental barrier to actually do it. Must be an oil company conspiracy thingy :lol: hell.. there used to be oil marketed specifically for honda where I come from and that took me quite a while for the 'enlightment' ...
Just out of curiosity I did a google on Harley Oil and look... there must be heaps of people who swears on these oils.. apparently different oil for different HD engine too :wink:
http://www.oilsandlube.com/Harley-Amsoi ... 0Chart.htm
-ariel circa 2007
krusty
Post by krusty »
The Harley D's oil is a 50W oil. They must have found anything thinner leaks and blows smoke, especially since many have quite a few years on them.
The SJ, SL deal I think is to do with the API specs setting lower minimum amounts of zinc in the oil (zinc is good for reducing valve wear from memory), so some can have too little to be good for bikes so you either have to look at the manufactuers data sheet or I know with some SJ stuff I have looked at there is a JASO VTW rating which I believe has to do with zinc levels.
mate i reckon they are the same.
u just slap a pic of a motobike on the front and the price tag moves up by $50
Castrol GTX can take the blame for the 'friction modified' legend......
If the oil does not say 'Friction modified' anywhere on the bottle,
and is rated to manufacturers specs (SG, SJ, 20W50, or 10W40), whatever, then it is *absolutely safe to use* in your motorcycle engine.....but that Castrol 'friction modified' oil is never to be used under any circumstances........unless you own a Bimmer or Moto Guzzi :wink:
HD's and older Dukes use straight 50w oil because they have to.
Smitty is dead right about not using fully-synth until you have properly run-in your engine..........although I would put the full run-in amount a bit further up the scale, min 6000k.
ps - if you run a mineral-based oil in an older air-cooled motor, don't bother changing to a synthetic or semi-synth........its basically a WOFTAM, and will *accelerate* oil leaks and/or oil weeps due to the change........
Mina is also spot-on...........and if you slap a photo of a boat on the front, well fuck me dead, you can triple the price !!!!
mrmina wrote:mate i reckon they are the same.
huh?
not sure about that
4 litres of Mobil1 10w-30 for my cage...$65 trade($73 retail) :shock:
even a cheaper oil like Penrite 30 is $35 retail
but
4 litres of Castrol 4T for the bike $32..retail
or GPS at $40
of course you could try BiGW 'Gold' at $5.99 for 5 litres
its a bargain :twisted:
not sure about the rebuild costs though......... :roll:
krusty
Post by krusty »
2stroke or 4stroke?
I get the Valvoline 2stroke outboard oil (usually best value and is in a 5L bottle) and I use it in both boats and lawn mowers for a few years. We go through a fair bit of 2stroke oil with our mowers and I found it cheaper to buy outboard oil rather than mower oil. I checked with valvoline and they said it would be fine, just not to use it in bikes.
