The cracks are hard to see unless you take the little cover off.
I've taken it back to the dealer for warranty and they are checking pricing of the replacement tail section. If it's under $500 they can order it straight away, if it's over that they need "approval".
It's all stock back there, aside from the ventura rack mount which is bolted to the subframe. Luckily I had things taped up a bit to stop any possible scratching on the Supers trip, so that actually held things together a bit.
My baby has a broken bum
