These are great! Rollastand- for bikes w/o centrestands
bonester
Post by bonester »
My Spada hasn't a centrestand which makes chain maintenance a bitch- previously have taken the bike down to the road (to share the chainlube with) and moved the bike a few inches and lubed a section of chain, then move again and again until the whole chain has been lubed- a royal PITA! :evil:
Anywho discovered this little gadget recently that takes a lot of the pain out of it- a Rollastand- the idea is to reverse your bike onto the rollers, and then you can rotate the rear wheel by hand, and lube the chain that way which is way better and easier. :lol: It also doubles as an aid for cleaning polished front wheels- you just drive the front wheel onto it- I guess you could use it in conjunction with a centrestand too for that duty.
Minus is that it doesn't stand the bike upright as a racestand does (oil changing etc) but the big plus is that it is small enough to fit in a saddlebag/gearsack/backpack, so you could lube your chain properly on a trip. :D
It cost $80 from Boyd Yung Suzuki. If you were handy I'm sure you could knock one up yourself. Am happy to share dimensions if you want to. 8)
Dude! thats pretty sweet!
Brand and product name please...
bonester
Post by bonester »
AFAIK it is just called a 'Rollastand'- that is all that is written on it. I threw the packaging away weeks ago, and just got around to using it. (Spada doesn't do much work) :)
FrogZ
Post by FrogZ »
OR you could just make one out of an old mop bucket.... :)
OR use a block of wood to prop up one side of the swing arm (like I do :oops: )
they have been out for a while.
they are only good for lubing the chain.
how does it work when u click it into gear and the side stand is down :?:
bonester
Post by bonester »
Mop bucket idea is great- the rollers would be about the same size- then you would need two lengths of angled steel and two long bolts and nuts to go thru the steel and rollers! :D
Dunno why you would want to put the bike in gear- risk of it riding off by itself- I use neutral and spin the wheel by hand. :?
Duane
Post by Duane »
i use mine for cleaning my front wheel. when washing my bike i have it on the rear race stand and the front on the rollastand
takes a bit of work to get them to spin, but shitload easier than moving the bike forwards or backwards. i hate half cleaned wheels.. btw used to be http://www.rollastand.com.au however, it's not working
also used to be $65 bucks. I got mine couriered in from a bikeshop in ringwood all up about 75 bucks inc courier.
www.bromancer.com.au
mrmina wrote:they have been out for a while.
SNAP!!!!
Wouldnt work on my bike!
bonester
Post by bonester »
Dunno why it wouldn't work with your bike- the idea isn't to use the engine to turn the wheel- must be done by hand.
Instructions:
http://www.hardlineproducts.com/rollastand.html
( the link mentioned earlier works- just get rid of the .au bit.) :D
kermitzx9r
I like your thinking
Post by kermitzx9r »
sounds like a good idea, and cheaper alternative to a front stand 8)
1997 ZX9R
If it's not green or it doesn't start with a K I'm not interested
thats what I need, must go and get one.
Johnnie5
Post by Johnnie5 »
its a great idea , IF you are going to take it on a trip
The long trips that i take are with other mates that ride so the sidestand gets used and a mate lubes the chain for me
for $80 you could buy yourself the race stand in the group buy :)
love the mop bucket idea though
bonester
Post by bonester »
Another bonus I would guess (and this would apply to a 'mop bucket' model) would be that you could disassemble it and make it even smaller for transporting on your bike- only held together with 2 bolts! :)
Re: I like your thinking
kermitzx9r wrote:sounds like a good idea, and cheaper alternative to a front stand 8)
cheaper than a front stand u reckon.
its used for the back wheel mate :oops:
bonester wrote:Dunno why it wouldn't work with your bike- the idea isn't to use the engine to turn the wheel- must be done by hand.
Instructions:
too much hard work for me mate.
for an extra $10-20 i would of gone the proper rear stand.
anyway, each to their own.
